Hi
I just saw someone having 4 of these for sale. They should be 5" fullrange unit.
I googled for a datasheet, but had no luck. Would anyone have a datasheet for these?
Thinking about playing with a open baffle system with these covering from about 400Hz and up.
The price is $41 (usd) pr unit. Is that too much?
Jørgen
Jørgen
Those are not fullrange but supertweeters used in the Tannoy Precision monitors from 2005. And no datasheets of those are published so nobody will be able to help you. The only ones you will find is the ones of the total monitor system: http://pdfstream.manualsonline.com/0/06d83fcc-1738-4a62-922b-2cdf5740f28a.pdf
Hi Waxx.
Thank you, but I think that is not correct. He showed me pictures. Unfortunatly they are already sold.
I found these images on Ebay, which are exactly the same, with the same markings.
I copied the images in case the Ebay post gets removed.
Tannoy range, Tannoy speakers, Tannoy Speaker Tannoy 7300, 0751, 5032 | eBay
Jørgen
Jørgen
