Push - Pull 50 Amplifier
There is no consensus as to what constitutes a good schematic.. And without specifications to judge by. I can only Cite the Big Lebowski in that :"well that's just like your opinion man"
I have a couple off the shelf board designs that could get you started, free no strings attached either way. So i cannot give you support for anything.
V4lve lover's free gerbers thread. Theres a Phase splitter with 6N1P/6N2P
UniversalHV REV2.0 is a good universal board for power supplies.
Theres the Phase splitter that can.. Well split the phase
And to top it all off. The 1.5A regulators are excelent, if i may say so myself. More in those here: DHT heater supply design
Cheers.
V4lve.
Norman Crowhurst documented a trasnformer coupled 45 PP amp in an old book. That might be a place to start. @egellings makes a good point. Maybe try 45's and save the 50's. They are darn near priceless. Regards, Bill
Sser2… I think one could get away with C coupling, in this 'modern era' where pretty high value C and VC and 'tough as nails' electrolytics abound. They simply didn't have those “back in the old days”.
None-the-less, if y'all go to PocNet to find the 50.PDF file, you will also note that the expected voltage swing on the grid is rather enormous by today's standards. Valves became a whole lot more sensitive with pentode designs, and with the advent of coated cathode filaments.
So… to actually get some audio output from a set of 50's, you would need to drive them at well over ±100 VP-to-P or thereabouts.
If your amplifier front-en is up to that, well … its almost an output - ready design to start with! Also note the recommendation of 2,000 or 1,800 Ω plate transformer impedance. Its not too bad… √(1800 Ω ÷ 8 Ω) = 15 to 1 primary-to-secondary transformation.
What's that… if it were toroid power trafo, a 250 VA unit, 240 VAC primary, and a 16 VAC secondary?
About right.
⋅-⋅-⋅ Just saying, ⋅-⋅-⋅
⋅-=≡ GoatGuy ✓ ≡=-⋅
The Toob GURU Alan Douglas did not give the 50 good marks. And the grid resistance needs to be limited to 10K, so a PP stage would need an Interstage Transformer.
But the Plate family looks good, an interesting challenge.🙂
  • 50 Tungsol.pdf
    50 Tungsol.pdf
