Hi Folks
I am sure that somewhere in the not too distant past, I read about a technique whereby connecting a capacitor between the + and - rails (not 0 volts) would cause the two rails to track each other fairly closely.
I can't find the details about the technique and how to choose the value of the cap. Has anyone got any information or knowledge about it
The application is a +/- 40 volt supply at about 4.5 Amps for a Class A amplifier that is housed in a separate chassis from the amp and connected by an umbilical cord.
The configuration is:
Toroidal transformer -> Diode bridge -> bank of 45,000uF initial smoothing caps -> umbilical cord to amp chassis -> bank of 30,00uF reservoir caps -> Cap multiplier -> amp module.
I think that the 'tracking caps could probably go anywhere in the chain, but gut feeling says on the second bank of reservoir caps.
Thanks for any help
Mike
Thanks for any help
Mike
