Rockford Fosgate Power 1500bd
As far as I know, they use 5k pots for the gain. The attached is from a similar amp.
All the new ones I stock are 20K for newer amps. The factory looking black ones are "insulated" hence the black coating on the knob. The only ones I've ever found like that are over seas.
I have used: 652-PTD902-2015KA502
In stock at Mouser but have a bare shaft with no black finish and no white dot.
They work fine aside that.
