DAC IC's mounted to adapters: PCM1794A/PCM5102/CS4398
All items are new and unused IC's mounted to DIP adapter boards. Soldering is clean and without errors using cardas solder.
All items 5 GBP each item plus shipping - free post UK
4 x PCM1794A SOLD
3 X PCM5102-APWR Audio D/A Converter ICs 2VRMS DirectPath 112 dB Audio Stereo DAC
2 X CS4398-CZZ Audio D/A Converter ICs Stereo Multi-Bit DAC 192kHz 120dB w/VC
2 X CS8416-CZZ Audio Transmitters, Receivers, Transceivers 192kHz Digital Audio Receiver
2 X SRC4192-IDB SOLD
2 x CS8421-CZZ 32-bit, 192 kHz, Asynchronous Stereo Sample-Rate Converter
