8x Large Aluminium Heat Sink from England - Lots of flat space for device, power amp
Taken from power amplifiers. Approx. weight I think is 1.76kg each, 414mm long by 112mm high by 35mm thick, two milled flat areas for mounting devices which run the full length of the heat sink. Lots of slots for screw fixings etc
Purchased used on ebay and unused for an amplifier project which I have since changed my mind on and am buying a pre-built chassis.
I could post out to Europe but would prefer England
asking £22 per sink
They are also on ebay for a little more, I am happy to sell there if better for you
