Class A supply power to output power ?
I have put together a JLH1996 class A power amplifier.
It runs off +/- 15VDC and has a 8 ohm speaker.
I have set current to 500mA.
How do I work out power into speaker ?
Is it simply IIR or is it more complicated ?
JLH1996 This is a class A amplifier. It consumes a lot of current. He is hot. You will need a large radiator. The optimal current is 1.2A. Installed by the regulator from above. There are options for an amplifier with Darlington or MOSFET transistors operating in class AB.
