akabak 3 vs akabak 2
Hello everyone
I would like to clarify some points with you
I have akabak 3 and 2
Or on two similation on the same design I find two different results
My project and a 4x? being designed
Concerning akabak 3 I put him in 4v source in source to have 2.83v in 2s / 2p on driver
Do I have to put in two sources and how much should I put in value source for 2 driver in series or how much in a single source in 2s / 2p?
I find this akabak 3.0 attachement 1et akabak 2.0 attachement 2
However, in akabak 3.0 when I connect the first 4 two segments of each hp the following segment takes the surface of the 4hp sement that akabak 2.0 does not
Which response curve should I take into account? Akabak3.0 or akabak 2.0
In akabak 2.0 what should i do to connect my first segment to the segment that connects them into one?
cordially, impatiently awaiting your answers
Charly
