ALEPH X
Good evening guys
For sale
If anyone is interested in an AlephX, I have had the circuit boards here for a long time and can't get around to realizing them. ALEPH DIY circuit board with the thickest gold-plated lines (100 nm) on FR4 circuit board. 20,5cm x3,5cm x 3mm .At the same time, the assembly of higher quality components has been made possible. the price was 49 € per board. The boards were made by Refentaudio. In addition, all resistors and potentiometers from Digi Key, and transistors of the irf 9610 are matched. On the board, the diameter of the soldering connections are slightly wider, so that higher quality components fit. I don't want to enrich myself just to get what I have spent. I can send you Digi key invoices and bom and schematic by email.one Link von denTrafos.
There are also two transformers 2x12V 400W they bought as good as new, but the film down below is worn see pictures. One weighs 3.8 kg alone. Link above trafos and Dokumentation:
Security Check
All resistances are always 2 more than you need, what is set in brackets on the bomb list is part of it.
excuses my translation.
I would have 320 Plus shipping.
Greetings alfred
Hallo People
I added a few more photos, but on the first screen I couldn't set all of them.
and we can still talk about the price.
Best regards alfred
