I've got an infinity ps-12. The amp and sub are built into the enclosure. Around 15 years old and rarely on.
After about 20 minutes of use, the amp starts making a unique crackling sound. No bass is present at that time.
If I take the amp out of the enclosure, and blow on the heat sync.. Or surrounding.. The crackling stops.
If I leave the amp sound board out of the enclosure, it's fine.
I can see one of the tubes or capacitor looks a little swollen and on the other side of the board there's a black scorch mark almost exactly where that tube is. I'll post pics and sound clip if I can
The right capacitor on the second photo looks vented. I would replace the two.
Check the grey 5W resistors and inductors solder pads also.
Check if there is leaked electrolyte (corrosive) on the board and clean.
I would say the board is the same as my JBL Northridge sub.
On mine I've drilled some holes behind the transformer in order to release heat.
