Amp Camp Amp rail voltage increase
I like the Amp Camp amp except for its relatively low power.
Would it be possible to increase the Rail voltage to 36V without reworking the entire ouput circuit? I have found Blocked as a plug in power supply. (Edit: since the link is blocked: It is a plug in supply, like a laptop supply rated at 36V and 220 W and a 6.1A max)
The main output fet irfp240 has a Vgs of 20V and this power supply at 1/2 VCC would be 18V. Am I cutting this too close? Your thoughts please.
