sb audience BIANCO-12OB150 Open Baffle
Hi
SB Audience Bianco 12OB150 Open Baffle|Speakerbuddies Lautsprechershop Hifi Stereo und Heimkino
I searched and found some info about this relatively new driver, but not a thorough review.
I would like to use it as a mid bass naked from 150 to 900 HZ.
This driver is reasonably priced here in Germany, but what are the compromises? It has a stamped Basket, is that a problem using the driver nude?
I read that the basket rings, but is that notable with music playing? Could I damp it with modelling clay or something like that? Does it make noises?
Has anybody already gained some experience with that driver?
Thanks for help.
Thank you, that seems to be a good alternative, efficiency might be a problem, since I need to lift 200Hz around 8dB so efficiency would only be 82dB/W in this application...
Measurements from SB are usually spot on, so the 95dB might be real.
