• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
For sale: Korg B1 enclosure with parts & wiring
Hello,
for sale a Korg B1, fully finished with the stock parts, but Duelund DCA signal wiring, without the B1 board.
I have used this for 3 months. Dead quiet, no ringing or any other problem. Reason for sale is, I build me a 4 channel version. Sale is without the B1 board, will turn that into an integrated amp.
As said, comes fully wired, Alps pot included. All you'd have to do is mount your own board -nuts and bolts supplied- and connect the signal- and power cable to the it, and you're good to go.
All metal is 5 mm aluminum. Top plate is removable for easy access to the measuring points and variable resistors. W*H*D = 130 * 275 * 70 mm. Pictures don't do it justice, it's a nice looking little thing.
Make me a fair offer, and it's yours. Am from the Netherlands, so shipping cost is a thing. Weight is 1 kg.
Greetings, Bart.
Images don't load. Retry. See above
