lm741 which is most suitable
If you are trying to upgrade them or just want a play then try something like the OP134. I would also add a small 10uF 50v standard electrolytic cap across pins 7 and 4 for a bit of close decoupling.
tape heads
do these look ok?
thanks Mooly! i guess it would not matter as both the erase an PB heads are common to case.( it just looks wonky)
up next would be confirming the 40khz bias oscillator is functioning(i wonder if anyone monkied with the bias trap filter?)
