Hertz HDP1 - Thermal Protection LED ON but works fine
I have an amplifier Hertz HDP1 and it is working fine. The only problem is that the TH LED is always ON. I checked the SW1 on the main pcb and it seems to be working fine. I followed the LED track and arrived till the board 37PW-HDP1-01 Rev:V0.0. I tested the transistor Q10 and it seems to be fine. The transistor is fed from R36 and D15 then from U3 (TL494C). Any hints what the problem might be? Thanks
