Sadly after a tussle with DPD on sending this out to the previous buyer the Hypex unit failed. It has been returned to Hypex, serviced and is in full working order. As a result of the last experience I am listing this for collection.
You are quite welcome to arrange your own courier to pick up but you will be responsible if anything is to happen to the items, I will not accept returns.
I am also leaving the units as they are. I won't be fitting the unit that has come back from Hypex unless you require me to but if you can use an allen key and a cross head screwdriver it's very simple. I've included photos of the case and the Hypex amp and also previous photos of the unit fitted. I will also be including a power cable and a custom DIN to XLR lead designed for use with Naim pre amps. This makes an exceptional combination and easily punches above the Naim NAP 200 and NAP 250 in terms of performance for a fraction of the price.
Collection: Oxfordshire UK
Price: £550
Reasonable offers considered
FEATURES:
Two channel amplifier
5W standby SMPS
Advanced over current protection
External controlled operation
Auto-switching (115/230V)
Low weight: 1055g.
Compact: 230x115x47mm
HIGHLIGHTS:
High efficiency
Universal mains operation
Flat, fully load-independent frequency response
Low output impedance
Very low, frequency-independent THD
Very low noise
nCore Specs:
Power (2Ω) 2X 450W
Power (4Ω) 2x 500W
Power (8Ω) 2x 350W
Channels 2
Weight 1055g
Dimensions mm 230*115*47
Mains voltage input 230V / 115V
Automatic input voltage selection Yes
Ghent Case:
193mm(W) x 58mm(H) x 315mm(D)
Color: Full Black
Face-Plate: 8mm thickness & NCORE logo
Top-Cover: 3mm thickness, with standard venting holes
Bottom-Plate: 3mm thickness, pre-drilled holes for Hypex NC502MP (Free drilling for other modules)
Rear-Plate: 3mm thickness, one pair of XLR sockets, two pairs of Binding Posts, IEC socket with power button
DC Supply for LED Dimmer: DC +10v ~~~ +26v
Price: £550
FEATURES:
5W standby SMPS
Low weight: 1055g.
HIGHLIGHTS:
High efficiency
Very low noise
nCore Specs:
Power (2Ω) 2X 450W
Power (4Ω) 2x 500W
Power (8Ω) 2x 350W
Channels 2
Weight 1055g
Ghent Case:
Color: Full Black
