I have 3 NEW EIMAC 75TL LOW MU TRIODE VACUUM TUBES as pictured. Can someone help me with the low and high-value per tube. I know nothing about these.
Electrical information? The datasheet can be found here - https://frank.pocnet.net/sheets/140/7/75TL.pdf
As for monetary value, the low is you give them away with free shipping, and the high is talking somebody into buying them for thousands. (It’s going to be closer to the former than the latter, sorry...)
We are happy to help you build an audio project with these tubes. That is what this forum is about. It is worth mentioning that it will be very expensive to build and require much custom construction, parts, and engineering, as these are not normally used making audio frequency amplifiers.
Because of the incredible hoops required to make a radio station transmitter tube make audio, it’s a reasonable suggestion to ask you to start with a simpler project.
greetings! I can buy them from you, as I have experience in making amplifiers with this lamp.
6L6 was right, these are very expensive, complex amplifiers and are also dangerous because they use high voltage
There are many Eimac pipes on Ebay and they are not expensive as few people can use them.
my amplifier is tuned exactly to - 75 TL, and they are less common
there are several in stock, but the design is very unreliable and they often fail
