Protection grill to Lowther
Not a grill, so perhaps no use. If you can source old tights, with a bit of effort a leg can be stretched over the whole speaker and sealed at the back. Putting mounting screws through without laddering is problematic. But it can work,keeps dust away from the units, and looks okay. Acoustically, I would say completely transparent.
Here's the original Hedlund's diagram for sinking the Lowthers in the front baffle (if you might want such a design).
Reversely,you can use the shown dimensions for precise cutting of a pair of 18-25mm thick MDF (the outer dimensions of your choice).On the resulting frames you can put any material you like (sonically transparent,of course).The resulting frames,when precisely cut,should hang/grip without any significant movement onto the loudspeakers' outer edges.
The drawing corresponds to modern production Lowthers' baskets.If you have some vintage units,be sure you measure and compare them as they might slightly vary.
HTH!
