Hlw am new here..and my English is not good
I want to build an amp like that of a car with 12vdc as input voltage
I just want to push a 100w amp for sub ( already made) and two stereo amp for mid and high i.e two lm3886 for mid and 2050 for tweeters
Can somebody help me a circuit for power supply that can supply over 300w
Any one with any suggestions
The car-sound shop will sell you hundreds-Watts 12VDC amps a lot cheaper than you can build one power supply.
Sound Ordnance M75-4 Compact 4-channel car amplifier — 75 watts RMS x 4 - $139.99
I can't tell where in the world you buy things. The Tanzanian market may be as desolate as Maine.
I suppose large inverters are equally hard to source for you.
https://www.homedepot.com/p/DEWALT-1000-Watt-Power-Inverter-DXAEPI1000/301887060
DEWALT 1000-Watt Power Inverter -- Connects to car's 12-Volt outlet or battery -- 2 standard (120VAC) AC outlets and 3 USB ports --- $ 149.00
