No doubt this is anathema to many, but here goes.
Having completed a lm3875 project, thanks to the kind help of some members of this forum, I'm back asking for suggestions for a new project.
I had the good luck of landing some ADS l810s, which need a 4ohm stable amp and a bit more power than my past project will put out. I'm currently using a Sony TA-AX500, but it too is (supposedly) not designed to handle 4 ohm loads, and so I'm nervous whenever I turn up the volume. It's a lovely amp, and I don't want to burn it up!
So, I'm thinking of building a new amp with my leftover 250VA 30-0-30 toroidal transformer. I have a heatsink, and can build an enclosure. I'm not sure if I have the time or skills or money to build an amp from scratch, so I'm wondering if any of you can recommend a set of eBay boards that would match my transformer and my speakers well. Also, I'm on a pretty restrictive budget.
For example, has anyone had any luck with the LJM Quad 405, or the LJM Accuphase e210 clone?
Thanks!
Thanks!
For a mostly plug and play option, I would look at the LJM “L15 mosfet” amp boards. ~$50 usd for a pair fully assembled.
Has 3-pair of outputs, which would handle 4-ohms easy with your 30-0-30 transformer. You would probably get about 75w per channel at 8-ohm and 100w at 4-ohm.
For full power potential (if you have enough heatsink) you would need a 40-0-40 to 45-0-45 transformer.
Also look at the L20SE with 2-pair BJT outputs.
Much smaller footprint and with your transformer should handle 4-ohms as long as you don’t clip the signal.
Thanks!
Thanks for the advice! I ordered the MX100, as a simpler and cheaper option. Will post results, if/when I get it put together.
That should be a good option for sure. The one I pulled up on eBay has built in rectification and supply caps as well as speaker protection. For a simple and straight forward hook-up.
Good luck on the build and let us know how you like it.
