I have a Hifonics Hercules 35th Anniversary Edition model H35-3000.1d that would go into protection mode when too much current is supply and would stay solid green when little current is applied but no sound whatsoever. Installed into my car to see if it was just the power supply that im using to power the amp was making it go into protection but the lights would flash from red to green. Opened up the amp and everything looks fine. Nothing looks blown. Could anyone help me? Thanks.
Post a good quality photo of the component side of the entire main board and the component side of any driver boards if no one can help.
What did you mean by:
"would go into protection mode when too much current is supply and would stay solid green when little current is applied"
You apply voltage and the amp draws whatever current it requires.
