Hi
I purchased a couple of good used 2446 J drivers. These are rated at 16 ohms. I threw my meter on them and I am reading 7.3 ohms on each one. Based on the spec sheet, I think it should actually be around 12 ohms.
The question is what is going on. Previous owner put in 8 ohm diaphragms or are they shot 16 ohm ones ?
Thoughts ?
Thoughts ?
According to the spec sheet, they are likely to be a 16 ohm coil.
DC Resistance: 4.3 ohms (H), 8.5 ohms (J) ± 10% @ 25°C
Very few inexpensive meters will read low ohms accurately. I had to pay $400. for a good Fluke
with low ohms back in the 70s.
That's probably very true as this meter I have is $30 special.
However, I think I am mixing up impedance with resistance. Measuring in ohms across + and - is DC resistance right ? How do you measure the impedance then ?
DC resistance treats the coil like a wirewound resistor. The AC impedance can be measured
by several methods. Without much test equipment, you can run a sine generator set for 1VAC
output through a 1k resistor into the voice coil. This forms a 1mA AC current source driving the coil.
Then with the 1mA input, the coil impedance at a given frequency is Vcoil / 1mA. For example,
if the AC voltage across the coil is 10mV, then its impedance at that frequency is 10mV / 1mA = 10R.
2446J diaphragms may have been replaced with 2446H, datasheet here:
2446H/J | JBL Professional Loudspeakers
"DC Resistance: 4.3 ohms (H), 8.5 ohms (J)"
I've observed this with my pair of 2426J's also. Both measure about 7 ohms DC resistance, even in a four leads Kelvin measurement.
Best regards!
Best regards!
Kay Pirinha
and are you using yours with a crossover that calls for 16 ohm drivers ? My crossover does and I was wondering if I needed to change anything ?
As I said in your other thread regarding your 2446J's, use your Paragon networks that already call for a 16 ohms midrange driver.
My 2426J's are out of service at the moment, but I'm tinkering with using them in my 4430 builds after adapting the resistive dividers in the N-3134 xover networks.
Best regards!
Best regards!
- JBL 2446 J Impedance
