R Robbie010 Member Joined 2019 2020-11-14 9:41 pm #1 2020-11-14 9:41 pm #1 Just wondering whether sources can be connected to the slave amp or can you only connect a source to the master amp? Thanks. ds23man Member Joined 2006 2020-11-15 8:15 am #2 2020-11-15 8:15 am #2 When using analog you have to connect the signal to the slave also. The digital sources are passed through the remote connection. You must log in or register to reply here.
