SPL Dynamicss-1200D PS Trouble
I received this amp. The owner connected a sub with lower impedance, the amp draws current and switched off.. I want to test the amp, but its not switching on.
On the PS Driver Board is a Jumper, seems like undervoltage release. If i switch that jumper , the amp turns on. Does anybody have a diagram for this. Iam sure, that there was something in the forum, but i cant find it.
So, with the jumper in the correct position, I have no supply voltage, or only 0.4v. Also at pin 3 at the lm293 is 0,4v.pin 5 the same. With the jumper in the other position, I have 12v at the supply pins, pin 1 is 1.04v.
Pin 2 4.35v
Pin3 0.14v
Pin4 12v
Pin 5 0.14v
Pin6 2.55 v
Pin7 0.28v
Pin 8 supply..
