I'd like to find out the dimensions of the Anti-Vibration feet that are offered in the DIYAudio Store. I did a search and could not find any specific information.
What is the diameter and height of the footers (not including the stud)? How long is the stud above the footer? How large a hole is required for the stud?
I want to make sure the footer mounting studs will not interfere with components that I am planning to install in the chassis.
Thanks.
Thanks.
The diameter is 44,5 mm (including the plastic part), the stud is about 5,5 mm about the rubbert part and the hole required is 5mm
Thanks Gianluca. One more question - what is the hole spacing for the plasticized steel handles?
Thanks again,
Jay
Thanks again,
Jay
