Hello everyone,
Im pretty new to amplifiers and all this, but some time ago I wanted to make a police siren amplifier (only the electronic air horn part) for my car. So I researched a little bit on the internet and was able to find schematics of some 80s and 90s siren amplifiers. With these I was able to recreate the exact air horn sound I wanted but now that I have the sound generated I dont know how to amplify it.
The Airhorn sound is a square wave of around 500 Hz and 10 Vpp.
I have an 100W 11Ohm and two 70W 8Ohm siren speakers.
Here is the schematic of the amplifier that is used by the original siren.
The design uses some kind of push pull amplifier which i cant get my head around.
My question now is if anyone can help me understand this amplifier or recommend me other designs that could work in a car, like a Class D amplifier maybe.
Thank you all
Best Regards
Thank you all
Best Regards
If you have a signal, you can use virtually any full range amplifier.
Full range class D amplifiers are available but generally not as cheap as class B or class AB amps.
To upload photos click the following:
Go Advanced
Manage Attachments
Browse
Upload
Repeat as necessary
Preview post to see how the post will look.
Click Submit Reply to send it to the forum.
Go Advanced
Manage Attachments
Browse
Upload
Repeat as necessary
I dont really want to spend too much on an amplifier and I dont think there is a chinese class D amplifier that can drive the 100 Watt speaker.
What's your budget, where are you located, are you opposed to buying used?
There's an absurd amount of used gear out there that will do exactly what you want at very low prices.
Also, I'm not sure you need the full 100 watts. What is it, double the power for a 3db increase?
Thats true, I wouldnt mind using the 8 ohm 70 watt speaker aswell.
Im located in germany so used from the US isn't the best solution but if you can point me in the right direction I would know what to look for on the used market here.
That complicates things slightly as the brands in the EU are quite different from what is sold in the US.
I would look for a 2 channel amp that can be bridged with an output of 100 - 200 watts RMS. These are typically quite inexpensive on the used market in the US, my guess is it would be similar in the EU but that's just a guess.
Thats seems to be the cheapest solution. I was able to find amplifiers for 10 - 20 bucks so I think I will go this route.
Thank you
Thank you
Just a little cautionary note if I may.
Here in australia... using any device that is similar to emergency vehicles (that includes lights, sirens, uniforms, identification, vehicle signage etc) without the proper permits is a federal offence.
The feds do Not take kindly to this offence.
I once saw a pair of 'kids' driving a car, playing with a home made siren.
They thought it was a right laugh.
Up until they were pulled over by the police and put in the back of a patrol car in hand cuffs.
can you give links ?Thats seems to be the cheapest solution. I was able to find amplifiers for 10 - 20 bucks so I think I will go this route.
Thank you
I don't understand... when would you use it?Oh sure, im not breaking any laws here if I just install the electronic air horn.
Links for used amps in Germany? Im sure you will find good deals in France too.
It's not to buy directly for germany, it's to have references for amplifiers you have choosen for this application.Links for used amps in Germany? Im sure you will find good deals in France too.
It's also what I plan to use : just look for amplifier board with supply converter includedClass D is perfect for the job. Every time i hear one i freeze😛
The listing for the one I bought is already down. But I was looking for something similiar to this.
Endstufe Verstarker Pkw Auto in Bayern - Kirchroth | Auto Hifi & Navigation Anzeigen | eBay Kleinanzeigen
or
RTO Endstufe Auto Verstarker in Schleswig-Holstein - Lubeck | Weitere Audio & Hifi Komponenten gebraucht kaufen | eBay Kleinanzeigen
or
Endstufe Verstarker JBL GTS 150 in Bayern - Teisendorf | Auto Hifi & Navigation Anzeigen | eBay Kleinanzeigen
or
or
I would use it like a normal car horn.
In many, many places this is illegal. It would be wise to familiarize yourself with your local laws regarding emergency signals before proceeding.
- General Interest
- Car Audio
- Police Siren Amplifier
