Pioneer SX-1010 Panel Lighting
I am new to this stuff and want to make sure I am accessing the right area to change my burnt front panel lights.
Is it best to remove the knobs and front panel or can I access the bulbs by removing the metal cover/cb shown in the picture just under the two leads going to the dial needle light??
Success...
Now another issue has appeared...
All mode lights work EXCEPT the GREEN FM light...
I suspect this one is requires front panel removal... Can you verify?
