Memphis Audio 16-ST500D protection curcuit help.
I repaired the power supply and 2 shorted irf640's on this memphis amplifier. However something is still damaged. Regulated is +-15, the power supply runs smoothly without the rectifiers. With the rectifiers in curcuit the amplifier flashes in and out of protection, the amplifiers draws about 2.5amps of current then not. Its fast the ammeter just swings as it attempts to power up. I could use some help identifying the problem in this protection curcuit.
The relay engages but it does not disengage with the protection flashing. It does shut down regulated voltage and rail, its very fast switching. Is they a way to bypass the protection to see what happens?
