PAM8403
I requste help of masters,
I want know about PAM8403, can i use module in bridge mode. I have no good knowlage of class D.
It is already in bridge (BTL) mode. When you have an amplifier circuit with a single output line, the other speaker terminal being connected to a supply rail or ground (eventually through a capacitor), there is a possibility for you adding bridging. With two active output lines for a single speaker, it is already bridged and you cannot add it.
