Power Acoustic LT1920-2
When the board is out of the heatsink it will power up and idle perfectly fine .
Once the board is back in the heatsink it will power up and after a second or 2 it will draw excessive current.
It almost seems like when the secondary ground comes in contact with the heatsink the amp will start drawing excessive current .
Any ideas what might cause this ?
Now the amp seems to do it even with it out of the heatsink
I had an amplifier similar to that one come into my shop a while back. It had multiple cracked and broken solder joints, particularly on the larger components and the large resistors in the output section, and check the the solder joints for all those jumper wires as well.
I say that to say this. Go over that amp thoroughly while wiggling and moving components and looking at the solder connections on the bottom of the board.
David
