Uses for 1N256
I just found a box of 9x 1N256 NOS in my stuff. I believe they are silicon rectifier diodes/Thyristors. They're really nice looking and have all the mica nuts and accessories. General Instruments JAKK 1958. I was thinking a power supply? What do you think?
You'll have to open the links in a new tab. Not sure why clicking doesn't work..
Milan looked them up, to be more precise:
SI rectifier
stud-mount
570V/0.2A
eq. BYX38/600
(source: VRT-ECA 97)
Although when I did a search I found 600V/2A
Your first spec is correct =570V/0. 2 amp-stud mount , made by Solid State Inc /Texas Instruments but 30 volt difference by other (later ) manufacturers is not unusual .
Talon Electronics of the Commonwealth of Virginia has two at $3.70 ( no express shipping due to Covid-19 .
Power supply ? in practical terms not for me but will obviously look nice if you fit them in a row and shine a spotlight on them.
How about a donation to a radio / TV / computer history museum. If you could find the right place they might even have a working piece that uses them.😉 Seems like those beauties would have been in something very high-end for the time ..
Good for your Karma !?
Cheers
Considering they are from 1958, are rather unusual and come with the original package, I think Rick is right and an electronics museum would be the most appropriate destination. Probably a computer museum or a museum of military equipment, I don't think they were ever used in broadcast radio or television receivers.
By the way, I do know of an audio use of SCRs: the former Dutch broadcasting organization NOS used to use them for switching between sources in large radio studio mixing decks. When you pressed a source selection button, for selecting what sound you wanted to hear through the studio monitors for example, that triggered one SCR and switched off a bunch of other SCRs.
