FS: Tubelab SSE populated board. PP transformers
Hello I have qty 2 identical Tubelab Simple SE boards. They are about 10 years old, but have been in storage the last 5 years. Solderwork could have been a little neater, but everything functions perfectly. R24 and R14 of the board look a little dark. This is because I changed from at AT7 input tube to a 12BH4, and didn't upgrade the resistor for increased current draw until a a few months later. Nothing falied, and I doubled the wattage of the resistor once I realized.
If you're worried about it, you can just jump the board with a wire.
Only $25 for the board! Fully populated with sockets and all parts. I have QTY 2
Also for sale are 2 output transformers. Edcor GXPP10-8-8k These are PP types, and NOT SE types usually used for the Tubelab SSE. I actually used 2 SSE boards in a differential arrangement to make a PP amp. Transformers are in excellent condition.
$40 for both transformers.
