H hdspeakerman Member Joined 2007 2020-09-08 12:24 am #1 2020-09-08 12:24 am #1 I just bought this Crown amp and am inputting Spotify with RCA interconnects. Is there anything to be gained by running the RCAs into XLR adapters and then into the amp? Will it hurt anything? H hdspeakerman Member Joined 2007 2020-09-09 8:33 pm #2 2020-09-09 8:33 pm #2 I heard from Crown. Nothing to be gained unless I use a Clean box between the amp and pre amp. You must log in or register to reply here.
