Bipolar capacitor/s
Good day gents,
I’m in search of a couple bipolar capacitors - 33uf 200v.
I’ve searched the inter web to no avail.
Couple of questions, the caps are being used on the secondary side of the power supply of a crossfire amplifier, in conjunction with the standard rail caps.
Has anyone tried making these before? (Two caps wired in series)
Any reliability issues with this method if done before?
I don't think they are using bipolar caps with pure DC. Are you sure that they are not being used in the audio circuit?
Photos?
Post #2 is a viable option, negative terminals together.
In some amps, I use 10uF 250v film caps. Some amps are perfectly OK with the reduced capacitance, some are not.
I was wondering if film caps would work in place.
In the pics attached they’re the two brown ones closest to the output FETs.
Those seem rather small to be 33uF and 200 VL. I'm used to the 33uF/100VL axyal ones, being longer and thinner, used in crossover networks. Probably they are placed in the NFB path but, oooh! that's the PS part, not the amplifier. Replacing with film caps would be better, but those won't fit inside!
The bipolars are connected in parallel with some 470uf 100v polarized (standard) electrolytic.
They connected to the source of the irfp9240s.
I’m gonna series two caps as suggested above.
