It’s a Rockford Fosgate punch 150 the problem is wont power on I hear a clicking sound in the transformer and the led has dim blink going on. I’ve already replaced the D44 power supply transistors and LM339 with a new one no luck.
Are the two orange primary filter capacitors within tolerance? At least one looks like it's swollen. Those take a beating in these older amps. The replacements should be rated for 105C and be very low ESR.
You should check the rail caps but they're likely OK.
