For Sale:
I have a transformer, completed power supply, and two completed channel output boards from a Chimpamp.com inverted LM3886 chip based amp. I built this amp myself, first kit I ever built. Shortly thereafter I started on the SE path. It has sat on the shelf for a few years. I ran the amp from a CD for two songs this morning to make sure it operated and then dismantled it.
All I am selling is the transformer (22v+ / 22v- /160VA), the populated power supply board, the two populated left and right channel PCB’s, and the heat sinks. The wire is silver tinned wire. I left the boards soldered together.
All of the other items such as binding posts, RCA inputs, potentiometer, power plug, fuse plug, etc I am keeping for my parts bin. If you want to try chip amps this might be a place for a newbie to start.
$70.00 shipped in the US. Paypal works best.
Thanks.
Thanks.
