mmats m3000.1d
Hi all
Amp came with complaint no audio. Visual checking found the jumper connecting two high side fets had burn the board.
I changed the two irs21844s ic and resoldered the connection and removed the bad fets. Now amp going into protect. I removed the main rectifiers and it is still going into protect. All output fets out of board.
