Rockford Fosgate Punch 150HD
I can't say for certain that they will cause a problem in this amp but they cause varying problems in other Rockford amps. Sometimes the problems are obvious, sometimes they only show up occasionally. If this is for a paying customer, I'd use the non-Z unless the amp originally had the Z version of the 540.
