Does anyone know what power supply fets and outputs this amp uses ?
As you can see someone tried repairing it before and put outputs in the power supply section .
So I’m not even sure if the outputs that are in the amp are correct .
No I just opened it up just now when posting I ha ent even been inside the amp .
Would 3205’s work In the power supply ? If so should I stick with the 22 ohm gate resistors or switch them to 47 ohm
Some of the photos I have of these rectifiers look like the one in the board. Other legitimate manufacturers may make diodes that look like the other ones.It's hard to say if they're counterfeit (substandard).
