Aurasound MR-12.4 / NS12-794-4A Repair
I recently stumbled upon a pair of Aurasound MR-12.4 subwoofers on eBay, new in box, for $300 including shipping. A fantastic price, I thought, for the NS12-794-4A's flamboyantly dressed twin.
I bought them, received them, and as promised, they were new in box. Unfortunately, all was not well with the subs.
Their coils were rubbing.
I removed the magnets and found that the plating on the neodymium magnets was bubbled on one, and bubbled/flaking on the other. I was able to remove the bad plating, but this left me with two problems:
1.) The magnets are neodymium/iron alloy. Without the plating, they will corrode/rust over time.
2.) The voice coil in one driver was scratched in several places by the flaking plating, resulting in shorting. Its coil reads 2.6 ohms instead of 3.5.
The seller was excellent about this, refunded me my money, and let me keep the subs. Needless to say, I want to try to repair them. So, I was hoping to do a little brainstorming with you all.
My initial ideas are to:
1.) Coat the exposed sides of the magnets with a high-heat primer, or maybe even a dielectric varnish to take care of any possible corrosion.
2.) Gently sand away the scratches on the damaged voice coil, and recoat it with varnish.
Anyone have any thoughts, concerns, or ideas? What would you try?
That's exactly what I would try.
How concerned do you think I should be about power handling if I sand the coil?
To avoid any issues, i was considering first trying to work apart the scratched areas of the windings that are making contact using the blunt side of a fine X-acto knife (and a magnifying glass so I can see. Haha!). But I have doubts about how effective that will be, and I may end up damaging it more.
They are shunted you need new coils (note: I don't have experience)
I bet you have a place (local) you can use for new ones ir recones.
If you make them yourself you need to measure all dimensions for specifications of new ones.
@hurrication : It was a lost cause, for me, anyway. The plating hadn't failed, the magnets had. Under the plating was a layer of magnet that was basically dust.
I tried repairing them anyway (peeled off the plating and coated the magnets with transformer varnish). But the gashes in the voice coil were too deep for me to sand away. So I sold the pair to someone who hoped to do better.
@maxolini : the seller was unaware of the issue, but issued a full refund and let me keep the subs when he was made aware.
I understand that this is an old post but I would like to step in, I helped design the Aura Drivers, unfortunately, the company was bought and the owner was warned about using the manufacturer that they went with ( it was cheaper) and the team knew that this would happen , the plating bubbled off . I am still friends with the main designer, we both have several of these drivers, at this point, there is no fix short of making new and seriously expensive motor structures but I will follow up if we find a solution.
G.
Thank you! I sold the 15s, but I do still have the 18s. It would definitely be useful to know of any possible fix if they encounter the same problem at some point.
Is there a manufacture date before which the plating was not prone to this issue?
So Aura was sold to a Chinese company ( went there 3 times, not a fan but amazing food!) the owner was clearly told to use a good plater and they did not, some went bad within a few years. No way to tell. I have some 12" that I think are still good we will see. We are in touch with an amazing transducer engineer and if anyone can find a fix them, it's him. The motor is compression fit, no way to remove the magnets and no way to replace the magnets , custom made and the field is rotated 90 degrees. My friend has many 15 " at this time, the only fix is to have new motors put on, this is crazy expensive, may not be worth it . It's a shame these are gorgeous drivers and the Aura NRT technology actually does sound better than conventional motors, they have amazing punch, the VC is under hung and the b field is super linear. I guess it's time to move on.
Reactions: Pallas and knarfor
G.
I hope something comes of this! I'm currently using an 2 NS15-992-4A's, 2 NS12-794-4A's, and 3 NS10-794-4A's. Also multiple of the shallow 8's in a different application. I have an irrational tropism to these drivers.
Unfortunately my NS18-992-4A developed a rub of some sort (I couldn't see anything really amiss with the magnet structure, though the coil appears to have a discoloration. I temporarily replaced it with a BMS 18n850 but I kept the NS18 in case I can get it repaired. I also had an NS15 die on me previously. Fortunately I had a spare.
G.
Did you work with Donald North?
