Now i have a different issue with the amp .
The 12 volt regulators are working correctly .
The 15 volt regulators in only getting 3 volts out of both the 7815,7915
Post a photo of the component side of the main board and the component side of any driver boards in the amp.
I took the audio driverboard out of the amp just to be safe so I do t blow new outputs or driver ic’s while testing .
With the audio driverboard out of the amp I have the same issue .only 3 volts on both 15 volt regulators
Measure the input and output voltage of the 15v regulators by placing the black probe on the ground terminal of the regulators.
- General Interest
- Car Audio
- Skar Audio 4500.1D
