Switching between sources
Hi there,
I'm building a dac that will have a tube output buffer. I want to make the tube output buffer optional - so I want to wire the output of the dac to a switch that will either pass the dac directly out to the rear RCA's or pass the signal to the tube buffer and then to the RCA's.
I'm thinking something like this will work, but I've never done this before so I thought I'd pitch it to the forum and see if someone had a better idea or could point out a problem with my plan.
Thanks!
A four pole double throw (4PDT) will do the job.
Connect outputs of DAC to centre row of terminals.
Actually, that's not what I meant, but in retrospect I see that I phrased it unclearly. It's perfectly clear when you literally translate it into Dutch, but in English it means the opposite of what I meant. The link in the opening post refers to a switch with silver-plated contacts and I meant to say that that may lead to poor contacts after a few months.
Gold plated contacts are what you need for reliable switching of low-level signals.
