PIONEER EQUALIZER SG-540 : Both Slider LED Lights Became Very Dimmed / Low :
The EQ slider leds / lights became very dimmed for no reason. the EQ still works great , he slider functions to modify sound still works fine for both channels.
Please find the attached pictures and service manual as well. Do you think some of the components might got weaker? like any capacitors etc? Need some help please. it's a vintage EQ which produces amazing sound and i have to fix it regardless.
Looking forward.
Mobin
The slider led lights became very dimmed for no reason. the EQ still works great , he slider functions to modify sound still works fine for both channels.
Looking forward.
Mobin
I assume both banks of fader leds have dimmed the same ?.
Check Q18 C=20V and E=11V and low AC ripple.
If you don't have a meter then replace C35 first (for testing purpose you can just bridge it with another cap) if this cures you are good to go, but I would also replace C36, C37, C38, C39 and C40 and resolder Q19 and Q19.
Max.
How is this slider lighting business working anyhow? I somehow doubt that they would have put the actual LEDs inside the sliders (necessitating lots of sliding contacts that may need a cleaning), something with the LEDs mounted at the top or bottom and some lightpipe magic would seem far less involved. But you just never know. Investigation will have to continue inside the slider module.
I think that is something like this. PTL60-15G1-103B2 Bourns | Mouser Greece
i assume English is not his first language, what i understand what he's trying to say to clean the slider banks with some cleaning agents, wd40 or alcohoal maybe and see if it makes any difference...
Each slider bank has 7 bands, not just a single adjuster as qouted. look for pioneer SG-540 equalizer slider. a picture is already posted above.
I don' say that is the case, i say something like this
I see the picture, this is a custom ordered part.
PS now i see your answer that you have done a try to another unit where the pot/led combination works fine.
Look at the led power supply.
Nope just measure between ground and positive end of C35, it should be 20V DC or so as per the schematic with maybe 1V of AC ripple.
If 20V DC is low and the AC ripple is high then C35 is dead/dying and like I said just bridge it with another suitable cap to confirm.
