New SSE Build from Texas
I decided to jump into a tube amp and started a Tubelab SSE build. I attached a BOM with all the parts I used. It includes everything, not just board components. Hope it helps anyone else starting.
For my wiring I ended up ordering 18AWG 600V tinned copper PVC from Remington Industries.
Wow, it is nice living close to Mouser here in North Texas. I placed my order at 5pm Tuesday night, by 8pm I received an email that it was out to ship. I received my order the next day by lunch!
I went with Edcor transformers. I placed the order, now wait. Power is XPWR035. The OPT is GXSE15-5K 8Ohm. The choke is a Triad C-14X.
I am into woodworking so I am going to build a custom chassis.
Here are some photos of my board with the resistors and capacitors installed. I will update as I go.
Mike
  • SSE_BOM_McAleer.xlsx.zip
The build I am starting mirrors yours. I was unsure about which cathode resistor to go with as well so I added a 3300 ohm resistor to my order. That way I can switch it in parallel to the 680 ohm base value and get ~560 ohm total without having to change anything. At least that is the plan.
Will be watching for your updates 🙂
Progress update
I received my sockets and got them soldered in. I also received my order from Edcor well within their stated timeframe. I am ready to put everything together now and build the chassis. Since I do woodworking I plan on building a wood frame chassis. I will probably start putting everything together on a board to test the build and determine the chassis size requirements. I will post progress soon.
Mike
