TDA2030 Single Supply Amp
Disabled Account
Joined 2020
Hi
Here is the board after cutting out. My workflow is to design the circuit in KiCad to get an idea of physical layout, then transfer that onto the copper with a pencil to mark out where I need to cut. The pads are then cut out using a dremel tool and a small grinding bit. I'd like to learn actual etching one day, but this is a lot neater than my normal ugly-style contstruction! I cut a really wide track between signal ground and power ground, so hopefull will get some nice isolation there.
Fitting the parts was real easy and I was doing a final continuity check for shorts with the DMM when I found a big problem.... The 2030 chip was blown, with the output shorted to earth. I de-soldered the chip and tested it and the fault remained.
Some LM1875 have been ordered, so it looks like this will turn out to be a LM1875 build instead!
