Audio Analogue Enigma dead display
Hello
I've got a "dead" Audio analog Enigma all in one system and I started to repair it.
The main fuse was dead and the valve (its an hybrid valve/solid state system) was fault on one channel. The fuse and the vavle were repaired and the unit is now working like a charm.
BUT the lcd display is showing some real issues to the point of making it useless.
I've opened the beast and I'm trying to replace it by a new one.
Its' a 16x1 LCD, marked E251530 94V-01. Google gives tons of possibilities and I can't find what could be the good replacement part.
The LCD is soldered on a specific board, but soldering is not an issue for me.
Can you help?
JM
