Free (Australia) - NE95W-04 driver pair
I've got 2 NE95W-04 fullrange drivers to give away. I will cover the postage so they find a home.
One of the drivers has a small 2mm dent in the dust cap as can be seen in the pic. These were taken out of a small Dolby Atmos speaker I built using dual drivers and now have changed the design to single driver with PR so I no longer need them.
Suggested box size 2.4 litres Fb=75Hz. For best sound balance a LR network is required to give some BSC. For 2dB use 1R + 0.2mH, for 3dB use 1R5 + 0.3mH.
In the near future I will be giving away a TPA3116D2 module as well as a Dayton DTA-2 module and both work well with this driver.
  • NE95w-04.pdf
    NE95w-04.pdf
