BUZ71 equivelent?
Hi, got an amp with BUZ71 mosfets I want to change out from the power supply as some are reading faulty, is there a newer equivalent I can put in and would I need to change gate resistors to suit? the amp is nothing special but interests me so would like to fix it up, it's a Precision Audio "Hot Shots", which is a bit of a joke amp but would like to see it work again!
Mark.
I think they are 47ohms..
You can likely use anything up to something like the IRF3205. That FET would be overkill for this amp and may require a slight change like increasing the deadtime slightly or changing the value of the resistors. Eliminating R108 may be enough if there is nothing but the gate resistors and the IC connected to it.
034 isn't 34. I could guess or confirm.
They would likely be OK. The Z44 would be better. You wouldn't likely need to make any changes with either.
To tell if a power supply is regulated, you vary the 12v supply voltage and if the rail voltage constantly changes from about 14v down to where the amp shuts off, it's unregulated.
If it has a range of 12v supply voltages where the rail voltage is constant and either the pulse width or the pulse amplitude driving the FETs changes significantly, it's regulated.
