Help with Ghent Audio and Neutrik Connections on my NC400 Ncore Build
Hi Everyone,
Im changing my conventional wired Ncore Amp to one of the kits provided by Ghent Audio but I am confused!
Question 1 - Which how I wire the Neutrik NL4? For each amp I obviously have 2 cables coming from the module to the case, but I have 1+, 1-, 2+ and 2-. Photo attached. How do I wire it?
Question 2 - Powercon only has 3 contact points unlike a normal IEC inlet. It has L, N and earth only. How should this be wired? I have two wires coming from the module, one read wire, one black wire.
Question 3 - Does the solderless XLR work in the same way as the conventional one? I can see on the solder less one that it has helpful numbers 1,2 and 3.
