Good quasi FR 2 inch?
Can you recommend any 2» semi fullrange drivers? I am thinking about splitting at 300 Hz or so to a sub.
A 2” might be a bit small to get to 300 Hz comfortably, and i still take to heart (as old as the report is) Zaph’s conclusion that none of the many 2” he tested were anywhere near as good as many 3” units. Quite a few more to choose from too. I have my favourites.
How small a box do you need? Very small — and maybe lower price are the only potential advantages.
And with an XO at 300 Hz you will find few subwoofers that reach high enuff to adequately eacjh 300 Hz — you need a woofer that goes up to at least 1.5k and higher would be better. The SDX10 might be a sub that does meet tha criteria — althou i woulduse a midBass coupler between the FR and the subs.
dave
That would be my 1st choice. A5.2 is little different (different VC mostly for marketing reasons for the Japanese market). CHN-50 would be a lower budget alternative. KJF audio is probably the closest source.
Do note that the colour names are left over from Gen 1 drivers, when they actually had those colours. They are now better described as copper & silver.
dave
If you mean a 2 inch driver frame size that limits choice. For mids and highs the Visaton FRS 5 X is excellent IMO. The Fs is too high though for it to really work for full range, but speakers that size are always going to be compromised.
The Visaton subtracts another 3dB or so, I guess because its cone is plasticised quite generously. Trading linearity for SPL. For small rooms, in a WAW, it‘s great fun, even with complex classical stuff. Cross around 600hz at least though.
A WAW is a growth on the FR concept, and if well done, give up very little vrs a more typical multiway, but still retain the FR magic.
We cross the FF85wk (and A5.2/3) at 250 Hz in Tysen V2, but the passive ended up at 450 Hz.
I do need to take new pictures, being finished they are now prettier (note that A5.2/3 will drop right into that box althou the passive will not be right). A seperate small 5.2/3 box (or FF85wk) and add woofers later. I have a number of helper woofers to go along with our small uMar-Ken/uFonken.
In fact downstairs i am running a set of uFonkens and using an empty box as a stand, still neeing to install drivers to use as a helper woofer.
dave
